Looking to upgrade our solar with either an arch or adding hard panels as the new 500SE has over the sliding windows. Does anyone have designs for an arch or suggestions on if it is necessary if you add the hard panels? We currently have 6 solara-soft panels.
If so, does anyone have someone they would recommend for the install on the east coast of the US?
Here is the design document that I produced for our build. This was fabricated and fitted by Bruce at Botany Appliances in Knysna. It was a great collaboration between us, KYC and Bruce - it worked out really well.
We achieved 4 x 530W bifacial panels + the 2 x 400W (no semi-flexibles). We are essentially independent on solar only (no genset). The dinghy lift has been fantastic.
Scott also asked “Does the 2200 W arch with the additional 800 watt panels on the deck provide all the power you need not to run the generator? Or even enough to run an AC unit during the day??”
The answer as with so many things that are part of the power equation is “it depends…”
It depends mainly on how much sun you get and how much power you use - and different boats use different amounts - and then you have location and weather…
For us the solar panels will normally generate all the power we need - we do not have a generator on board (we do have powerful secondary 24v alternators). We boil kettles, cook on electric, make water, run the washing machine and generally don’t worry about power usage. We don’t always get back to “float” every day but that is where the reserve in the battery bank helps (24kwh lithium).
It is rare that we have to run the engines just to charge the batteries (a few cloudy days).
The two 110A/24v alternators can produce over 5.5kw of charge current - I’m very happy not to have a generator with all its spares/servicing/weight/space and fuel costs.
We don’t normally run a/c at all - occasionally we might run it in dehumidify just before bedtime. We prefer to have hatches open and airflow rather than being cooped up inside. Our “treat” when we have excess power is normally to put the water heater on and have hot showers.
It has to be said that latitude does have an effect on solar production - but so does temperature of the panels, how high the sun is in the sky etc. We live in the tropics full time aboard Tourterelles.
We do get a “boost” from the bi-facial panels (they are 530W on the main face). The most power I have ever seen them produce is 749W each! Cool panels and fierce sun…
Note : Tourterelles is currently in the midst of an electrics refit after which we will have 2 x 130A/24v alternators and 30kwh of battery capacity.
For those of you that are interested here are some numbers I gathered a little while back - primarily to work out how much power we used at sea and at anchor.
At that time it was 16.4kwh at sea and 12.9kwh at anchor.
Figures are taken from the Victron MPPT’s.
Note pMax is a maximum for the day in watts (not a full day average).
It is really giving a very good overview of your system which seems to be effective and which I do find optically appealing - especially with the bifacial panels.
We do have a manual crane installed on Bahati which is lifting the tender and swinging it onto two resting brackets at the back. I assume the height of the crane would be able to swing below your solar array frame.
Some questions:
Did you install the brackets and systems at the beginning while the boat was being built or is it a retrofit?
What if your solar panels need to be (partially) replaced? Is your mounting design catering for a scenario when you might have to install slightly different sized panels?
As we have an existing setup at the back, I would try to modify your design to match our existing frames and setup. In addition to the pictures and documents on this post would you be able to share the CAD files so that I could check and compare dimensions?
In order not to temper with the existing stainless steel tubes I am thinking about designing a new set of brackets which could be attached with stainless stell clamps similar to the clamps next to the Weber grill in the picture.
Would you be able to share a rough cost overview of the components to estimate the whole investment?
Yes the arch was designed in from new - but officially an after-market item.
No I haven’t added specific features to allow panels to be changed - it fell into the “too many unknowns” category - but it would be great if feasible. I did design in some (5-10mm) gaps around the panel but that didn’t happen when they built it - so they are quite tight. That will be a separate challenge if and when the time comes.
I will try to find the CAD files and send you a link separately.
If you are not going to implement a dinghy lift then I think you may be able to use brackets - and you could certainly lighten the structure.
I’m about ready to cut the dinghy lift off…Carolyn would not let me pack them with 1lb of C4 and have the real official send off in line with my feeling for them!
Can anyone tell me what these are made of? Are they just fiberglass? Or some other material? Will a grinder work?
From the photos Wiz sent to me when they did theirs. I’m not sure if they are members of the forum yet. You can see one cut off and one in the process of being pruned.
I also remember seeing two of the arms leaning against a wall at Knysna (probably the ones that didn’t get fitted to our boat). I did not look closely but I think they were strong GRP.
Hi Geoff the reason is the big solar arch precludes the use of the arms and boom gantry lift - the solar panels e tend too far. So the frame for the solar arch doubles up as a dinghy lift and the arms are not used.
We did a solar arch that allowed the boom lift. The line would just clear the arch. It was fabricated in St Maarten.
Kato Marine in Annapolis is top notch. Probably priced accordingly.
Might be someone good near Norfolk that is a bit cheaper.
We had the same specs Tourterelles used to install our arch in South Florida with Dedicated Marine and they did a very good job. We installed 4 590 bifacial panels that regularly put out 650. Very reasonable price and great work. The owner is a unique guy but knows his stuff extremely well. We did not install the dinghy lift as we have a hydraulic one but might end up taking it off and adding in this set up.
