Continuing the discussion from Decals - Carving & Marking:
We replaced the cabin and cockpit recessed lights with these lights from Hella Marine.
https://www.hellamarine.com/shop/interior-exterior-lamps/downlights/euroled75-downlights/
https://defender.com/en_us/hella-marine-euroled-75-led-downlight
We used this dimmer. https://defender.com/en_us/hella-marine-2-group-light-dimmer-998572001
Hella sent a new dimmer even outside of the warranty window when one was flickering. Great customer service!
Great light quality and beam spread. It was a huge improvement to the original lights, which were like spot lights.
I did look at the Hella units for our boat but opted to eliminate any variables and keep things as easy as possible by using identical replacements. The Hella units are slightly deeper but otherwise looked like they would fit.
The equivalent OEM part numbers that were fitted to our 500se by KYC are…
29 x BCM, Orlando 75 3406-75C-B2W-S-04__30FXX_OS6 White 75mm
Orlando 75C | BCM - Benedetti Lighting
3 x BCM, Orlando 75 3406-75C-B2W-S-04__BR3XX_OS6 Red/White 75mm
7 x BCM Orlando 60 3406-60C-B1.5W-S-04__30FXX_OS6 White 60mm
Orlando 60C | BCM - Benedetti Lighting
All with polished stainless steel trims.
The bedside reading lights with USB ports are…
Casolux, Martha Wall Lamp USB Touch Dim
Martha Wall light USB Touch Dim – CASOLUX
The corridor lights are…
FS Marine, 7100 ‘Alcyone P’ Wall Light
7100 ‘Alcyone P’ Wall Light - Gineico Marine AU
The “slap” lights in the equipment lockers, showers and forepeaks are
Frensch, F-22 LED, #7322 Warm White, Touch no night light
F-22 LED - Frensch
The engine bay slap lights are the F28’s.
The blue courtesy lights over the exterior steps are…
Hella, Easy Fit Step Light LED 12v/24 BLUE with Chrome Cap
LED Courtesy Step Lamps - Low Profile
The blue courtesy lights around the coachroof are…
Hella, 2XT 959 680-611
Hella Blue LED Courtesy Light
